TH350, rotation of shafts - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-23-2009, 06:39 AM
I have posted this elsewhere, and this is my final stop hoping I can at least get one post I've read so much on this site in the past, I know you guys rock!
Good Morning!
Ok, I've installed a transgo 350-3 manual reprogram kit and am having the following issues after installing a new drive and driven gear, any help is greatly appreciated! Thank you!
*EDIT* - when I turn the rear output shaft, It feels tight, but then the speedo-gear turns and the most front input shaft turns as well. But then, turning the most front input shaft by hand, the rear shaft and speedo gear does not turn. Normal?
Ok, I figured out how to get the rear housing off, took some dexterity and finger cramping... but the drive and driven gear were replaced.
I noticed with the rear housing in place, but not fully tightened I could turn the front, very front input shaft (smaller diameter) and the rear output shaft would turn as well. I could also see the end of the speedometer/driven gear spinning inside the gear housing.
Now, when I torqued down the Rear Housing, and turned the front shaft, the rear output shaft no longer turned, the speedo gear no longer turned.
I took the housing off, the gears looked fine, the drive gear was still in place with the clip on the shaft. I put the housing back on, and noticed that when torqued down again, the speedo gear would not turn, and the rear output shaft would not turn. I un-torqued the hardware again, and noticed that at a certain point of having the housing about a 1/16 - 1/8 inch off the trans on one side that the rear output shaft and speedo gear would start to turn again.
So, now that I'm stumped, what am I doing wrong here if anything? When torque down should that rear output shaft be turning when turning the front shaft?
Thanks ahead of time!!
Pic below shows the gap that allows the rear output shaft to rotate.
Old 06-23-2009, 12:09 PM
No, it shouldn't necessarily turn. It needs fluid pressure to lock the clutches or band. I don't think you have a problem.
Old 06-23-2009, 01:52 PM
Thank you, I needed the reassurance much appreciated! I can't wait to get it in the car and go for a ride.
T-350 Rebuild Tech jakeshoe Transmission - Rearend 10 10-05-2008 04:58 PM
7 wheel tire rotation powerrodsmike General Rodding Tech 7 09-28-2008 12:02 PM
Getting correct filter for TH350 75gmck25 Transmission - Rearend 2 06-21-2008 01:04 PM
Transmission swap: TH250 to TH350 Torque converter issues. 35oldstruck Transmission - Rearend 5 05-21-2008 04:43 PM
Stock TH350 capacity 307malibu Transmission - Rearend 7 11-01-2007 11:16 AM
