TH350 Seal - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-24-2011, 07:44 PM
TH350 Seal
I have my engine & TH350 trans removed from the car. I want to get a idea of how difficult is it to replace the front & rear shaft seals for the trans and do the work my self. Does this take special tools? Can I get the replacement seals at auto parts stores? I have not worked on a trans before so can you recommend any internet sites where I can get directions or photos?
bt
Old 01-24-2011, 09:17 PM
ericnova72's Avatar
More for Less Racer
Seals are relatively easy to replace, just pop them out and drive the new ones in. The front pump/converter neck seal is a bit tougher because you have a long shaft and a half moon of bellhousing limiting your access but it is nothing terribly difficult.
Most auto parts stores will have or can order both seals.
Old 01-25-2011, 10:47 AM
ericnova72, I noticed you are in SW Michigan. I used to live in St. Joseph, Michigan. What town are you in?
bt
Old 01-25-2011, 11:07 AM
cucumber1949's Avatar
T-Bucket, Corvette, Mustang
If you don't already have it, consider getting a copy of Ron Session's book on the TH350. JMO.
I levered the front seal out with a large screwdriver - careful not to nick the input shaft with the screwdriver so be firm but precise. I used a block of wood and a little Permatex on the outer surface of the seal ring to install the new seal - just go slow if it is your first one.
The rear shaft seal on the tailhousing is just as easy. Remove the tailhousing from the trans. I have seen these tailhousings cracked by those that use too much force to remove the old seal. Once the old seal is out, use a seal driver or a press to install the new one, again using a thin smear of Permatex or other such for a sealer.
Old 01-25-2011, 05:41 PM
ericnova72's Avatar
More for Less Racer
bt
I'm about 15 miles south of Battle Creek, outside a little town called Union City.
T-350 dipstick seal awoodman Transmission - Rearend 5 06-09-2009 05:50 AM
TH350 Pump seal question aberenz Transmission - Rearend 5 04-30-2009 09:12 PM
low reverse piston seal th350 jeffvega Transmission - Rearend 2 02-17-2009 07:51 PM
TH350 Tool and seal trouble. Pontiac Rumble Transmission - Rearend 8 10-16-2007 10:13 AM
Th350 seal removal SBC-S-15 Transmission - Rearend 1 04-04-2005 09:41 PM
