3/8 - 16 thread as mentioned... some are metric: 10mm x 1.5 thread. unless some person rethreaded the shaft
At the Bonneville Salt Flats, first gear is known as 130 mph. |
I know a guy who almost messed up a 700R4 trying to install a 3/8ths 16 nut on his 700R4
"I won't be wronged . I won't be insulted, and I won't be laid a hand on. " |
700r4 is full metric. t-350 was full standard (early years) and some cases had metric and standard threads.... same with the t-400 trans
DID NOT know that some Turbo 400's also had the metric thread on the selector shaft
I have cut new 3/8-16 threads on a metric shaft trans (700) to save the additional work to replace the shifter shaft.
Good to read you got it figured out.... remember these trans are over 30 years, probably been changed around a bit. have fun
| th350 to 700r4 swap?????????? | trumick | Transmission - Rearend | 6 | 09-23-2005 08:19 PM |
| TH350 to M21 or TH350 to 700R4 | thecamaroguy | Transmission - Rearend | 6 | 02-10-2005 01:18 PM |
| S-10 tail pipe size | catscan4free | Engine | 3 | 02-23-2004 02:34 PM |
| size of nut below pitman arm | CHEV66JB | Suspension - Brakes - Steering | 4 | 05-31-2003 11:42 AM |
| Gm steering wheel nut | Busted Knuckles | Suspension - Brakes - Steering | 5 | 01-16-2003 11:22 AM |
