th350 set up - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-25-2006, 07:42 AM
mybad66's Avatar
Last journal entry: 66 gto rebuild
th350 set up
are both the vacuum kickdown and cable kickdown required to be hooked up for proper operation of the tranny. First time with an automatic and when i got the car the cable kickdown was not hooked up to anything
Old 11-25-2006, 07:51 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
The vacuum modulator is not for kick down. It is there for the trans to determine engine load by the level of vacuum to it.
Low vacuum = higher engine load and this will raise the main line pressure of the trans. The upshifts will be at a higher RPM/road speed too.
Detent cable does raise pressure a bit more on heavy throttle. It provides kick down and later upshifts
Old 11-25-2006, 02:21 PM
mybad66's Avatar
Thanks all i can learn will help
th350 in 67 Tempest csob Transmission - Rearend 1 02-19-2006 09:45 AM
TH350 wont do anything - a few questions justchris Transmission - Rearend 2 02-15-2006 11:56 AM
Cobalt drill bit set. BadSS Garage - Tools 8 01-15-2006 07:54 PM
putting a FI set up on 406 blake carstensen Engine 10 10-17-2005 06:15 PM
TH350 kickdown cable andybird Transmission - Rearend 4 07-25-2003 06:54 PM
