TH350 shift gate pattern VS Powerglide? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-22-2012, 07:28 AM
How much difference is there really? I have a hurst quarter stick for a th350 sitting around I'd like to use on my power glide. Can I just grind down the 3rd gear stop "tooth" on teh gate and run it? Or is the spacing between gears different?
Thanks...
Old 03-22-2012, 10:39 AM
B and M Part Number in Jegs 80713 comes with new shift gate for the shifter and new transmission shift lever.
Shift gate? Kenrick Binegar Transmission - Rearend 3 01-28-2012 09:33 AM
Is the shift pattern on a ford c3 and a c4 the same? Quarter Flash Transmission - Rearend 1 06-16-2011 03:53 PM
powerglide to th350 column shift? fireforsin Transmission - Rearend 3 05-06-2008 04:56 PM
Powerglide Won't Shift 97SC2 Transmission - Rearend 1 05-23-2005 08:06 PM
Reverse shift pattern brainsboy Transmission - Rearend 3 06-29-2004 02:51 PM
