th350 shift kit - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-27-2009, 02:31 PM
jgh64pkup's Avatar
Last journal entry: new et streets
th350 shift kit
what are some advantages of a shift kit?
how can i make my own?
would it be worth the hassle?
anything would be great thanks
Old 11-27-2009, 03:42 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
look at this THREAD HERE
Top of the Trans- rear end forums located at...
read the section with photos of the separator plate and drill holes.
mayb this will help you a bit
Old 11-27-2009, 09:49 PM
jakeshoe's Avatar
The biggest advantage of all the commercially available valve body kits (for perfomance use) is that they dual feed the 3rd gear clutches.
B&M's, TCI's, TransGo's, etc.
All that I have seen do this.
This takes care of the major hydraulic weakness in the TH350.
Some of the kits have you drill the feed holes way too big IMO and this can (WILL) cause intermediate sprag failure.
Keep the feed holes no larger than about .135" (I prefer .125" on the 2nd feed) and keep the 1-2 accumulator function active on a TH350 it will not break parts.
Old 11-28-2009, 12:23 AM
jgh64pkup's Avatar
so thats all there is to a shift kit
Old 11-28-2009, 12:49 PM
jgh64pkup's Avatar
and people pay 40 bucks for instructions
Old 11-28-2009, 01:48 PM
jakeshoe's Avatar
You are paying $40 for the instructions, the new seperator plate with dual feed, some gaskets, and usually a heavier pressure regulator spring (usually not required).
The dual feed is worth twice that....
I gave instructions in the sticky on this forum so that those who are doing a complete rebuild would have the option of completing the dual feed portion internally and not purchasing a commercially available valve body kit.
If you are not going to do internal mods, the commercially available kits are an excellent choice. I prefer the TransGo but have used them all. Some of them give bad advice for orifice sizing.
Old 11-28-2009, 02:34 PM
jgh64pkup's Avatar
so go with a transgo
is there any way to install it while its in the truck
Old 11-28-2009, 09:24 PM
jakeshoe's Avatar
Yes,
It is designed to be installed with the trans in the vehicle.
Old 11-29-2009, 10:52 AM
jgh64pkup's Avatar
is there a special way to do it to keep the little balls from falling out
Old 11-29-2009, 10:55 AM
jakeshoe's Avatar
Assembly gel or vaseline.
Old 11-29-2009, 11:13 AM
jgh64pkup's Avatar
cool
thanks
do i need to toque the valve body bolts to a certain spec in in a certain order
Old 12-01-2009, 02:01 AM
SSedan64's Avatar
Originally Posted by jgh64pkup
cool
thanks
I start in the center and spiral outward, circular pattern.
Torque Specs here>> http://th350.netfirms.com/pages/7a2-71.jpg
TH350 Info>> http://th350.netfirms.com/browser.htm
Old 12-01-2009, 02:42 PM
jgh64pkup's Avatar
thanks is that all i need to know
Old 12-02-2009, 12:56 AM
SSedan64's Avatar
Be careful when you're lowering the Valvebody so the checkballs down scatter. It will be messy as the fluid keeps dripping forever. Much easier if you can use a car lift. Leave a Pan bolt in so you can tip the pan & pour the fluid into the drain pan, then remove the last pan bolt. Also be sure to clean everything well.
Old 12-02-2009, 02:51 PM
jgh64pkup's Avatar
it has a drain plug
so do i use brake cleaner thats what a guy told me to use when i took the valve body off the first time
4L60e 2-3 shift slow after installing kit ckucia Transmission - Rearend 3 09-01-2009 11:09 AM
Th350 Shift Kit Question leejoy Transmission - Rearend 15 03-16-2006 01:33 PM
What will a TH350 Handle? Many Th350 Quetions, Shift kits? Warrant Transmission - Rearend 2 12-18-2005 09:46 PM
400 th shift kit help gpeak Transmission - Rearend 2 01-07-2004 04:51 PM
TH350 will not shift at WOT quadman_20 Transmission - Rearend 5 04-14-2003 11:20 PM
