th350 shift point - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-09-2010, 08:11 PM
th350 shift point
alright i asked this in the engine tech. i did not get any replies so i guess they thought i was crazy. The problem is i already know im crazy, i just want to understand why this happened... lol. anyway. Just went from a stock 359 with headers to a rebuilt 350 with big valve heads and higher compression. With the old motor the transmission would shift hard into second. With the new motor it doesnt jerk as hard. Itd a rebuilt trans only a couple years old, and the fluid is full of course. i was a little weary to post this out of fear of looking like a fool. I just dont understand i would think that the new motor and power increase would make it shift harder? is there something im missing?
Old 09-09-2010, 08:23 PM
Aerotech's Avatar
You have less vacuum with the new motor, which is one factor that determines when it shifts. Nothing wrong with a softer shift, probably better for everything in the long run. Make sure the vacuum source for the tranny is from the manifold behind the carb. You will probably not get the firm stock shifts with big-valve heads.
Old 09-10-2010, 10:32 PM
that would make sense but i forgot to mention one thing. i have the vaccuum thing for shifting disconnected at the moment and am shifting it manually because it was going bad when i switched motors
Old 09-11-2010, 02:12 AM
Aerotech's Avatar
You must use the vacuum line if you expect a TH350 to shift properly. It knows when to shift better than you do, and if you override it and shift manually, you are losing performance. You can hold off the shifts a little with modulator and governor adjustments, but just letting it do its thing is usually best.
Old 09-11-2010, 02:28 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Leaving the kickdown cable disconnected is sometimes done, but you should use the modulator. If the modulator is "going bad", replace it.
You may be experiencing a different shift 'feel' because the new engine is generating more torque, causing the converter to stall a bit higher and this can also make the shifts feel softer- but the main thing is the trans needs to be fully functional, as in not needing rebuilt.
TH350 delayed manual 1-2 shift RocketSwede Transmission - Rearend 17 10-12-2008 01:26 AM
low shift point elcaminodragster Transmission - Rearend 1 04-28-2007 09:20 PM
4l60e shift point question silm man Transmission - Rearend 2 02-19-2006 04:23 AM
Late shift point bct Transmission - Rearend 2 05-27-2005 08:59 PM
c10 - th350 to 700r4 swap column shift 70chevyc10 Transmission - Rearend 7 10-25-2004 10:35 AM
