th350 shift problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-15-2011, 10:50 AM
i have a 1976 chevy 1/2 ton with 400 short block it has a th350 transmission also 4 wheel drive. cannot get reverse and forward geers will only work in 4 low lock and 4 hi lock. also vacuum module is much larger than normal. could this be off a th400? and would that matter?
Old 05-15-2011, 11:43 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
if you have vehicle movement problems in other transfer case shifter range when not in 'lock' on the t-case...
you do not have a trans problem , you have a t-case problem or rear differential problem
th350 shift adj again sooper Transmission - Rearend 5 05-22-2010 11:58 AM
What will a TH350 Handle? Many Th350 Quetions, Shift kits? Warrant Transmission - Rearend 2 12-18-2005 09:46 PM
TH350 won't shift down to first conestogaman Transmission - Rearend 2 12-15-2004 10:27 AM
TH350 will not shift at WOT quadman_20 Transmission - Rearend 5 04-14-2003 11:20 PM
TH350 B&M Shift Kit bizkit075 Transmission - Rearend 0 02-01-2003 10:34 PM
