th350 shifter adjustmen on a 69 camaro - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-22-2005, 11:20 AM
dawg's Avatar
NAVY VETERAN
ok I won a new horseshoe shifter as they are called and hooked it all up .
I set the car in drive (actual. not as indicated on the shifter.)
I disconnected the linkage at the tranny.
set the shifter in the drive position
loosened the linkage bracket on the tranny pan.
hooked up the linkage and tightened it down.
now i get park-reverse-neutral-drive- 2nd
the shifter goes back a bit more but wont catch first?
i hit the stop before it engages first.
Old 05-23-2005, 04:35 PM
Lonestar's Avatar
"May the Schwartz be with you"
Last journal entry: Finally getting going...
Is the shifter for a 2 speed powerglide?
Old 05-23-2005, 06:25 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
The last couple aftermarket auto shifters I had, instructed the installer to set them up in first and make sure the rest worked after that.
Those were both Hurst parts and the rest of the manufacturers might have differring methods for the same result.
Old 05-23-2005, 08:07 PM
Crosley's Avatar
Wiki Edits: 1659
I believe dawg received an answer over on a Camaro board.... ?
It does sound like a detent shifter problem
'36 P/U, 69 Camaro subrame engine help!!! Apathy93Z Engine 1 12-08-2004 06:54 AM
TH400 Swap - 69 Camaro, currently TH350 paulsubs Transmission - Rearend 3 10-30-2004 12:16 AM
TH350 shifter lemans-tom Transmission - Rearend 0 12-10-2003 10:07 AM
Shifter rebuild on a 68 Camaro duanecourt Transmission - Rearend 3 06-12-2003 06:19 AM
