th350 shifting problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-25-2011, 10:49 PM
hi all,ive started to have a problem with my t350 transmission.under low revs it doesnt hold long in 1st and 2rd and by 30kms shifts to 3rd.i need to put my foot flat to return to 2rd.under high revs gear change is fine.also when i stop it sometimes takes off in 2rd gear.i live in new zealand and finding it hard to get info on chevys so any help would be great.
Old 04-25-2011, 10:53 PM
here is a link that leads to a link that will have instructions on how to adjust your linkage.
th350 tv cable adjustment
Old 04-25-2011, 11:43 PM
i'm having the same problem with my th350,it shifts from 2rd to 3rd way to early.let me know if you find where the problem is.
Old 04-26-2011, 01:18 AM
chevykid90's Avatar
454, what turns your crank?
Last journal entry: Replacing bearings and crank
X2 on the modulator, and i may be wrong. it could also be your torque converter... my race blazer is kind of the same way, i have a TH350 and i have to manually shift it, if i don't it will burn it up.
Old 04-26-2011, 07:11 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
kuta1972 ... I merged your other t-350 shift timing problem post to this thread.
Please read dates on threads when you search... you posted to a 8.5 yr old thread.
Shifting ? regarding a TH350 Madmax305 Transmission - Rearend 2 11-23-2010 10:51 PM
TH350 shifting problem 68LemansConvertable Transmission - Rearend 13 08-03-2010 07:40 AM
Shifting on a TH350 ryno2287 Transmission - Rearend 2 07-02-2009 12:54 AM
TH350 Warm Shifting Problem thurr Transmission - Rearend 4 11-08-2004 01:01 PM
Th350 shifting and stall problem sack Transmission - Rearend 2 09-14-2004 09:12 AM
