TH350 shifting problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-21-2011, 06:58 PM
ok i bought a brand new TCI TH350 from summitracing, its behind a 355cid, for some reason it is very picky on when it will shift into 3rd. it stays in 2nd under light load and full throttle. I've tried adjusting the modulator numerous times and it doesnt seem to help, also it has a clunk in the transmission when i come to a complete stop?
Old 08-21-2011, 09:50 PM
Crosley's Avatar
Wiki Edits: 1659
I would appreciate the snarky comments not be posted, Please stick to tech information on the question that was posted.
There is no need to respond to my post, just stop the snarky comments
Old 08-22-2011, 08:42 AM
dinger's Avatar
Does the tranny come with a shift kit? I think I would call the manufacturer and see if this is normal. Any other thoughts out there? Sane thoughts, that is....
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
th350 shifting problem kuta1972 Transmission - Rearend 4 04-26-2011 06:11 AM
TH350 shifting problem 68LemansConvertable Transmission - Rearend 13 08-03-2010 06:40 AM
th350 shifting KGRIFF Transmission - Rearend 3 06-17-2007 12:41 PM
TH350 Warm Shifting Problem thurr Transmission - Rearend 4 11-08-2004 12:01 PM
Th350 shifting and stall problem sack Transmission - Rearend 2 09-14-2004 08:12 AM
