TH350 shudder? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-09-2006, 03:31 PM
TH350 shudder?
I have an 81 C-10 with a 305 and a th350. I noticed the other day, that the pan gasket was leaking. So, I replaced the filter and pan gasket. Everything seemed fine. I have noticed now that I have a slight shudder when I accelerate gently. It almost feels like something small is rolling around in the bed of the truck. It shifts firm and down shifts like it did before. I should mention that my boss told me to run type-f fluid. Could this be the problem? My boss is a drag racing freak and he builds all of his own transmissions. I have type-f in my Camaro's th400 and it seems flawless.
Old 10-09-2006, 07:06 PM
You didn't by some chance put the filter on 180 degrees out did you, this will starve it a little.
Old 10-09-2006, 07:14 PM
I use Type F and nothing but Type F in all my chevy trans. I doubt the fluid has anything to do with it
Old 10-10-2006, 04:08 PM
I put the filter in the way it should go in. I didn't know the filter could be 180 off. I noticed today, that it only does this when it is warmed up? Could I have over-filled it? I'll check the fluid level again tomorrow.
TH350 STILL slipping after long drive 87442lover Transmission - Rearend 10 01-02-2007 05:19 PM
th350 in 67 Tempest csob Transmission - Rearend 1 02-19-2006 09:45 AM
TH350 wont do anything - a few questions justchris Transmission - Rearend 2 02-15-2006 11:56 AM
T-350 to 700r4 swap? trumick Transmission - Rearend 6 09-23-2005 08:19 PM
TH350 to M21 or TH350 to 700R4 thecamaroguy Transmission - Rearend 6 02-10-2005 01:18 PM
