TH350 slippage??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-28-2008, 02:58 PM
TH350 slippage???
I have a professionally built TH350 that slips in third gear and when hot will not shift into reverse? I believe I have plenty of fluid, after market dipstick shows it is full. When cool trans works fine after about 15 miles at 45 mph step on gas and engine revs, at 75 mph seems to work better but not perfect. If it was low on fluid when first driven how long does it take to damage components? Any help to sovle problem without pulling it out would be helpful. Thanks Spike
Old 08-28-2008, 04:27 PM
Overdriv's Avatar
You are checking the fluid level with the engine running?
After you run it just a few miles the fluid should be everywhere it needs to be.
Is it getting hot?
Do you have the vacuum modulator connected to engine vacuum?
Old 08-28-2008, 09:23 PM
SSedan64's Avatar
Aftermarket dipsticks are known to be inaccurate. You may want to drain the fluid and drop the pan. When full the fluid level should be even with the top of pan rail or bottom of trans case. If the full mark on your dipstick is off, use a file and correct (V-notch) for full & low marks.
Old 08-29-2008, 12:39 PM
Overdriv,
No, I am not checking with the engine running. I have been checking it hot and cold and have similar results. What is best way to check? All vacumn connections are made and double checked.
SSedan64,
If I drop the pan you say the fluid should be at the top edge, therefore I will only have to replace and equivalant amount of fluid...correct? I assuming than if the fluid is overfilled it will start coming out as soon as I brake loose the pan gasket and bolts? If this is the true "FULL" level I could than replace pan and fill accorddingly and this would be my full line on the dipstick. Agree? Sounds like an easy way to confirm fluid level and at the same time mark dipstick properly.
Thanks for your help.
Spike
Old 08-29-2008, 03:40 PM
SSedan64's Avatar
You allways check the fluid with the engine running on an automatic trans. That may be your problem. If you check it with the engine off the level will be much higher and incorrect.
Old 08-29-2008, 06:37 PM
350 slipage
spike, a 350 tranny and covertor bone dry take 10.5 quarts depending on pan. i run a 350 on circle track with 8.5 quarts or it blows it out. if your on the stick you should be ok.now to your prob... i see this all the time. either the valve body is lose or there is a plate that looks like a hockey stick in front of vb they put fliud transfer plates under it with shift kits. i have found them lose or someone forgot to put the stock plate back on also.. no rev,no 3rd. hpoe this helps drove me crazy the first time i saw it . found by dum luck... good luck frank..
Transmission swap: TH250 to TH350 Torque converter issues. 35oldstruck Transmission - Rearend 5 05-21-2008 03:43 PM
Stock TH350 capacity 307malibu Transmission - Rearend 7 11-01-2007 10:16 AM
TH350 wont do anything - a few questions justchris Transmission - Rearend 2 02-15-2006 11:56 AM
T-350 to 700r4 swap? trumick Transmission - Rearend 6 09-23-2005 08:19 PM
Is this TH350 a turkey? 360Camaro Transmission - Rearend 19 11-11-2003 06:43 AM
