TH350 slipping after sitting 8 months. normal? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-09-2010, 12:38 PM
Cknarf's Avatar
Pontiac Pilot
It it normal for a transmission to hesitate to shift if the car has been siting for roughly 8 months? My engines back in my formula, and before the rebuild, the tranny seemed fine, with an occasional rough shift to second. Now it acts as if its out of tranny fluid. I just put two quarts in, and it still does it. If I drive for a few blocks will this straighten out?
Old 07-09-2010, 01:13 PM
sqzbox's Avatar
My pipes are my music
Where did the 2 qt's of fluid go while sitting for 8 mo? If you have any room left on the dip stick to add 12 oz. you might try a can of lucas transmission conditioner. It might help the seals and free up any sticky valves in the tranny. What year is your formula? If it's a 700R-4 it's not uncommon for a firm shift going into second when the tranny is still warming up. If you do drive it some more, check the fluid level a couple of times till it stay's on the full mark.
EDIT: sorry, I re-read your post and missed the 350TH. Same fix.
Old 07-09-2010, 05:00 PM
Cknarf's Avatar
Pontiac Pilot
thanks, ill check the fluid a few more times and drive around a bit more.
It's a '75 with '74 455.
TH350 Slipping gilby246 Transmission - Rearend 2 08-02-2006 09:42 PM
TH350 3rd gear slipping? 2kcj Transmission - Rearend 1 04-10-2006 06:20 PM
Fuel degradation after sitting for months Mad Maggot Engine 7 10-09-2005 01:03 PM
TH350 slipping 87442lover Transmission - Rearend 1 06-12-2004 10:09 PM
TH350 Trans Slipping when warm 64SS Transmission - Rearend 1 09-29-2003 07:32 AM
