Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - TH350 small leak from a pump bolt...?
Old 07-03-2012, 04:27 PM
ericnova72's Avatar
ericnova72 ericnova72 is offline
More for Less Racer
Those pump mounting bolts are supposed to have a thin rubber coated sealing washer under their heads to prevent leaks.
Your leaker has either no washer, the washer is damaged, or the bolt is loose.
