-   -   TH350 small leak from a pump bolt...? (http://www.hotrodders.com/forum/th350-small-leak-pump-bolt-221219.html)
Dryden 07-02-2012 01:47 AM
Hi
My TH350 is dripping at a rate of maybe one drop a minute from a bolt hole in the pump!
I can clearly see, by positioning a torch properly, that the oil does not come from above the six-o'clock bolt - it comes through the bolt's threads.
Anyone got an idea how this can be? I bought the TH350 used, now it's in the car with everything hooked up...
Here's a picture to show what bolt is leaking... (not my trans)
http://farm8.staticflickr.com/7106/7...13d3e814_o.jpg
ericnova72 07-03-2012 03:27 PM
Those pump mounting bolts are supposed to have a thin rubber coated sealing washer under their heads to prevent leaks.
Your leaker has either no washer, the washer is damaged, or the bolt is loose.
Dryden 07-03-2012 09:57 PM
You're right! I just bolted up the pump, not knowing that they need to be sealed like that... Thanks for the info :)
