TH350 small leak from a pump bolt...? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-02-2012, 01:47 AM
Dryden's Avatar
Hi
My TH350 is dripping at a rate of maybe one drop a minute from a bolt hole in the pump!
I can clearly see, by positioning a torch properly, that the oil does not come from above the six-o'clock bolt - it comes through the bolt's threads.
Anyone got an idea how this can be? I bought the TH350 used, now it's in the car with everything hooked up...
Here's a picture to show what bolt is leaking... (not my trans)
Old 07-03-2012, 03:27 PM
ericnova72's Avatar
More for Less Racer
Those pump mounting bolts are supposed to have a thin rubber coated sealing washer under their heads to prevent leaks.
Your leaker has either no washer, the washer is damaged, or the bolt is loose.
Old 07-03-2012, 09:57 PM
Dryden's Avatar
You're right! I just bolted up the pump, not knowing that they need to be sealed like that... Thanks for the info
TH350 leak cullencombs Transmission - Rearend 10 04-09-2012 06:37 AM
th350 trans leak. oldguy829 Transmission - Rearend 1 12-24-2010 04:03 PM
TH350 Leak superhero Transmission - Rearend 5 12-04-2006 09:19 PM
2 bolt vs 4 bolt main 350 small block CanadianCory Engine 9 10-30-2005 09:31 PM
TH350 Leak just_football Transmission - Rearend 4 09-20-2003 12:15 PM
