TH350 speedo gear calculation - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-28-2007, 10:16 AM
dawg's Avatar
NAVY VETERAN
if you math wizards can check my math for correct speedo gearing
27.1 inch diameter tire
tire revs per mile 768.0
3:73 rear ratio
speedometer calibrated at 1000 revs per mile.
I come up with a 7 tooth drive gear (on tranny shaft)
20 tooth driven gear (on speedo cable)
that will give a .50% margin of error.
Id rather the speedo read a bit high than low.
Old 04-30-2007, 10:34 PM
8 driving 22 will get you closer.
http://novaresource.org/speedo.htm
TH350 drive gear replacement dawg Transmission - Rearend 8 04-28-2007 09:07 AM
no 1st gear in my th350 blueday Transmission - Rearend 2 04-26-2007 06:48 PM
th350, no 1st gear!! judis951 Transmission - Rearend 19 03-17-2007 08:41 PM
THM speedo gear seal mhamilton Transmission - Rearend 4 02-19-2006 10:36 AM
th350, no third gear ummduh Transmission - Rearend 2 04-03-2003 03:44 PM
