Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - T-350 speedo gear question?
Old 07-26-2012, 11:45 PM
mmerlinn mmerlinn is offline
Wiki Edits: 85
Originally Posted by cobalt327 View Post
The drive The driven gear always has the greater number of teeth of the two gears. Hope that helps some.
That is true for TH350s, but is not always true for other applications. Example, I know that some Toyotas use a 27 tooth drive and a 22 tooth driven as well as other similar combinations. Same with Subaru with 23 tooth drive and 19 tooth driven.
