Originally Posted by tobyj17
I haven't ordered the gears yet, but i did finally get the speedo hooked up, 30 mph off!
One thing i forgot to ask, are these gears the same with a TH350 and Th 350c?
Yes and no. The TH350C uses a driven gear that has less teeth than the TH350 may have. The TH350C is usually 17 to 25 teeth or so and the non C has more in some cases. The size of the housing will be larger for the larger (30-35 tooth- plus) driven gears, IIRC. You should be able to narrow this down doing a search on it.
