TH350 Starts in 3rd - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-06-2011, 09:36 PM
TH350 Starts in 3rd
I recently rebuilt a tranny with my cousin and did so with the help of a video. We followed everything on the video. We did take out the middle seal in the first stages of assembly and then plugged the passage with JB weld at the front of the tranny where the pump goes on.
When I start out in 1st gear with the shifter in 1st 2nd or D The truck is is 3rd gear already. it lacks power and stays in 3rd gear. It does not kick down either. I dont know if it is another problem either because the tranny was bad when i got the truck so i never really had a chance to see how it worked before the rebuild.
Any advice or suggestions would be greatly appreciated!
Thanks
Josh
Old 01-06-2011, 10:38 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
Check the governor for proper operation, I think it may be stuck in the open position.
Rich
Old 01-07-2011, 07:06 AM
ok i will have to check that out... Thanks. It may be a few days since I live an hour from where my truck is... Ill keep ya posted tho thanks!
what causes hard starts abas_abas Engine 8 05-25-2009 10:45 AM
Starts but won't run Sherm Electrical 2 05-29-2008 09:02 PM
And it starts... Weimer Off-Topic 16 09-23-2005 02:39 PM
almost starts femadorob420 Engine 7 01-10-2003 09:09 PM
New TH350 Starts out in 3rd gear? roygrimm Transmission - Rearend 2 01-22-2002 07:37 PM
