th350 still useable? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-22-2007, 09:11 PM
Cape Cod Bob's Avatar
It has been sitting for years from a boneyard. Had a small amount of water in the pan when pulled . Very clean inside. I can turn the output shaft easy enough and the inner input shaft also but he outer input shaft does not turn. Have tried with shifter in different pos.. Should i be able to turn this? Is there any way other the installing and running to tell if this is still useable. Suggestions greatly appreciated.
Old 07-22-2007, 09:22 PM
Jmark's Avatar
If it were me and it were sitting that long with water in the pan, i'd get it gone through before risking all the time on the install.
TH350 or TH400, Which one? NOlowrider Transmission - Rearend 4 04-10-2006 07:27 PM
th350 in 67 Tempest csob Transmission - Rearend 1 02-19-2006 10:45 AM
TH350 wont do anything - a few questions justchris Transmission - Rearend 2 02-15-2006 12:56 PM
T-350 to 700r4 swap? trumick Transmission - Rearend 6 09-23-2005 09:19 PM
TH350 to M21 or TH350 to 700R4 thecamaroguy Transmission - Rearend 6 02-10-2005 02:18 PM
