TH350 Sun Gear question - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-13-2011, 09:25 PM
Hey all, just a quick question:
Is this normal for the sun gear washer? Its a 1976 th350. According to the photo in sessions book it should have more teeth but instead looks like some teeth were, quite frankly, beautifully broken off.
Old 05-13-2011, 09:58 PM
Is there suppose to be teeth on the actual shell? I did find material in the actual grooves of the sun gear itself...
Stupid questions I know, but first time rebuilder here and can't get a good answer out of the book.
Heres the shell:
Old 05-13-2011, 10:06 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
yes, the shell should have teeth on it.
the washer wear... if it looks scored, flip it over.
The misssing teeth on the washer.. some washers have teeth that are gone , other washers have full set of teeth.
Old 05-13-2011, 10:12 PM
Thanks for the quick response.. I know crappy photo's but the interior of shell, (where teeth should be) is completely flat and burred. Looks like i'll be ordering a new assembly. The actual sun gear had some metal bur's in between teeth, so I'm guessing it had a bit too much play.
I lost reverse on this transmission, had a little too much fun in the mud.
TH350 no second Gear Bug Eye Transmission - Rearend 1 11-03-2009 07:24 PM
no 1st gear in my th350 blueday Transmission - Rearend 2 04-26-2007 07:48 PM
th350, no 1st gear!! judis951 Transmission - Rearend 19 03-17-2007 09:41 PM
TH350 - Not Going Into Gear Houston54 Transmission - Rearend 3 09-18-2006 11:54 AM
th350 not going into gear phillip24 Transmission - Rearend 4 03-29-2004 09:02 PM
