TH350 swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-29-2004, 06:48 AM
New Member
TH350 swap
I am going to replace my Powerglide with a TH350.It is in a '68 Camaro.I know I can use the existing cross member and drive shaft but what about the shift cable setup?
Will I have to cange the shift cable setup?
Old 04-29-2004, 07:47 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Cool
You will need the correct bracket that bolts to the tranny and the shifter arm for the manual shaft of the tranny.
As I recall early Camaro T-350's had two bosses on the tranny case just above the pan rail that the shift cable bracket bolted to.
I have owned 7 gen 1 Camaros but , I sold the last one in 1985, so my memory is a tad fuzzy
