TH350 swap to 700R4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-25-2007, 07:54 PM
TH350 swap to 700R4
Ok so i have a 82 silverado and im swapping out the th350 for a 700r4. the truck i think came with an overdrive transmission because the gear selector says automatic overdrive. i got a 700r4 from a 90 suburban and was wondering how do i get the speedo to work. The truck has a mechanical and tranny doesnt. Also wat else do i have to do. Please for the love of god someone help.
Old 12-25-2007, 08:15 PM
Jmark's Avatar
You can pull the tail shaft housing and remove the speedo reluctor and install a standard gear. You will need to figure your drive/driven gear combination, hopefully some of the tranny guys can help.
If the 350 had the long (12") tail housing, the drive shaft will go right in without a length change. Mount is in the same place on both trannys. You will need to remove the old kick down cable and re-install the TV cable and set it correctly.
Should be a pretty straight forward swap. If yours previously have an OD, the wiring plug should be under there somewhere too.
Mark
Old 12-25-2007, 11:06 PM
This is a 700R4 with a mechanical speedometer setup ...
Go here ... for the parts and information
http://www.transmissioncenter.net/sp...n_______va.htm
Old 12-26-2007, 08:57 AM
31 five window
Last journal entry: grill and rear end
Jmark, I do not claim to know it all, so explain please? I have done several TH350 to 700R4 swaps and have always had to move trans mount back. Is it possible they changed on newer models?I understand on drive shaft length because of tailshaft lenth, but tail shaft length on TH350 does not move mount position as far as I know.
Old 12-26-2007, 01:51 PM
Jmark's Avatar
I stand corrected on the mount distance. The info I found online today states the 700 mount is 1 3/4" farther back than the 350. Maybe the original holes are still in the frame? One can only hope.
Mark
Old 12-26-2007, 01:54 PM
31 five window
Thanks Jmark,thought I was having another brain fart.
Old 12-26-2007, 06:29 PM
Jmark's Avatar
I'm actually not supposed to be posting here. All the pro's were gone and I took a chance! LOL
Mark
200r to 700r4 swap help dch921 Transmission - Rearend 5 11-19-2007 07:19 PM
What's needed for a th350 to a th400 swap? Fil Transmission - Rearend 2 09-16-2004 03:09 PM
700r4 tranny swap chevcamz28newbie Transmission - Rearend 6 08-06-2003 02:52 PM
700r4 vs th350 chevcamz28newbie Transmission - Rearend 2 08-02-2003 08:20 AM
Need help with 4L80 to th350 swap Jason Transmission - Rearend 0 06-19-2003 09:00 PM
