Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - th350 to t56
Thread: th350 to t56
Old 02-11-2005, 09:20 PM
M&M CUSTOM's Avatar
M&M CUSTOM M&M CUSTOM is offline
Wiki Edits: 9
Like Chazmac said, you should not be able to use the flywheel at all with the 305.
The flywheels from the 86 up 305 won't even work on the older engines.
I haven't really kept up on the later blocks but I know they are not compatable at all with the earlier engines.
