th350 tail swap? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-29-2003, 10:02 PM
Post th350 tail swap?
Hi... Got an 84 camaro I am putting a th350 in... Was running with a T5 so having to do some mods... Is it possible to replace the tail housing on the th350 with one that has the set up for the torque arm? Or can you give me an idea of what year and model car I need to look for that can give me what I need here?
Old 08-26-2003, 07:39 PM
New Member
thinking..
Cars like the Vegas and.....i can't think right now, but there should be plenty laying around at most tranny shops that have been in buisness 20+ years. And cheap too
Old 08-26-2003, 09:14 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Cool
there are kits to remount the torque arm . Places like summit sell them.
I've never seen a T-350 tail housing with the correct pattern on it for the torque arm mount for your camaro. Usually only some mounts for vibration dampners on the bottom of the tail housing.
As I recall the T-5 is a bit longer than a 6 inch tail housing T-350?
Will a 9 inch tail housing on the T-350 be needed as if you were removing a 700 type tranny?
