TH350 tailshaft question - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-11-2010, 03:11 PM
Is there an o-ring that seals this unit to back of tranny? Had a long tailshaft but it exploded when a u joint gave on me. Cracked to peices. Had an old short shaft laying around. Just curious. Thanks.
Old 02-11-2010, 05:27 PM
There is a small round tail shaft seal that goes on the tail shaft of the transmission and then your tail shaft just slides up in and then your done.
Eric
Old 02-11-2010, 06:32 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
this is a bit confusing to me...sorry
if you are talking about the tail housing that bolts to the main case.... there is a square cut O-ring seal on the tail housing
if you are talking about the sealing onto the slip yoke , there is a metal sleeve on the out put shaft with an O-ring inside of the sleeve.
Old 02-11-2010, 07:27 PM
Thanks guys. Sorry to confuse. I was talking about the side that bolts to the case. Thanks again.
TH350 quick question kringold Transmission - Rearend 0 09-22-2006 10:24 AM
T-convertert For Th350 Question NavyNova73 Transmission - Rearend 2 06-25-2006 10:17 PM
Th350 Shift Kit Question leejoy Transmission - Rearend 15 03-16-2006 01:33 PM
TH350 TCC question billtiller Transmission - Rearend 2 02-16-2006 06:25 PM
T-350 rebuild question Marcus Transmission - Rearend 3 07-01-2004 07:48 PM
