TH350-TCI manual shift valve body questions.... - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-21-2010, 08:14 PM
Livin in ChevHelle
Hey fellers..
I installed a new TCI manual shift, forward pattern, valvebody in my TH350 a few weeks ago and have been fairly satisfied with it. Car is a 72 Chevelle, SBC 355cid, TH350, 3800 stall etc etc.. It was my first one, so I took my time and I thought it was an easy mod. Man...When you shift it...IT SHIFTS...HARD! Love it...
My questions/curiousity is..when you have manual control of the trans, select 3rd(drive) and take off from a stand still(gently) what components are in play? I understand it generates enormous heat(fluid,t/c, entire system) and I rarely(ok once) do it, but was kinda curious. I did it once just to see how it felt, but the slipping I feel, is that the t/c or the clutches?
thx
Old 04-21-2010, 10:10 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
when the trans shifter is in 3rd gear , you have the forward clutch applied, the intermediate clutch applied, the direct clutch applied
Old 04-23-2010, 05:39 AM
Livin in ChevHelle
IC... and the slipping I fee is all the t/c? It feels 100% normal.....JW
Thx
manual valve body tomthecomic Transmission - Rearend 2 11-01-2009 07:50 PM
master cylinder interchange runn141 Suspension - Brakes - Steering 7 05-03-2009 05:15 AM
700r4 tci valve body adrules12 Transmission - Rearend 15 10-25-2008 07:39 PM
Turbo 400 Manual valve body Tbucit Transmission - Rearend 3 05-10-2006 09:30 PM
th350 1st gear manual shift problem desman Transmission - Rearend 6 02-08-2004 03:15 PM
