th350 teflon stator ring question - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-20-2011, 10:54 AM
I am building hopefully a high horse capable th350 but I ordered teflon rings from transtar they are orange in color but appear to be to narrow I havent measured them yet . I ordered another set from a race trans builder and they were exactly the same package my pump is the roller bearing type are the teflon rings suppose to be narrower than the cast iron ones or does someone offer wider ones . They are probably .020 narrower than the cast iron rings.
Old 03-20-2011, 11:10 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
use them , they work fine. I have installed thousands of them.
Watch the diameters (2) for the stator
Old 03-20-2011, 11:27 AM
Thanks I am just to picky probably just kind of freaked me out .
I need a th350 front pump gasket and o-ring. Where can I buy these locally? scapegoat Transmission - Rearend 6 05-30-2010 10:20 AM
Positive stop Teflon Oil Seal question Rufus_2 Engine 1 10-25-2009 10:01 AM
Stator Shaft Help Brkingspider Transmission - Rearend 2 03-23-2009 04:14 AM
TH350 Accumulator sealing ring CamSweet Transmission - Rearend 2 01-05-2008 07:48 PM
TH350 output carrier lock ring.. CamSweet Transmission - Rearend 4 12-14-2007 01:05 PM
