TH350 or TH350C - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-30-2003, 07:46 PM
Post TH350 or TH350C
How do you tell which is which from the outside between these two 350's.
Old 05-30-2003, 09:04 PM
Post
A th350C has a plug for a wire connector on the drivers side on top of the pan rail a few inches back from the shift linkage.
Looks just like a weaker th250C, the 250 has a band adjustment screw pointing down at a 45 degree angle right above the cooler lines.
Old 05-31-2003, 08:32 AM
Post
Thanks for the info. Truck came with 700r4 but was switched over to th350. It has the plug from the harness but no place for it to go. I wasn't for sure if th350c worked on electric or maybe vacuum or fluid pressure for lock-up to engage. CRAIG
