th350 or th350c? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-20-2008, 08:04 PM
th350 or th350c?
i just recently purchased a tranny form a buddy of mine to stick onto my 86 305 thats in my 80 malibu....im trying to decide what stall converter i need for it, the motor is all stock. i also need to figure out if my tranny is just a th350 or if it is th350c. is there any way i can find out just by looking at it? and what is the differences between those two trannys. thanx
Old 03-20-2008, 08:21 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
LOOK HERE for some pointers.
Old 03-20-2008, 08:38 PM
so basically since the 350 tranny that i have has the 2 wire plug on the driver side....whats the purpose of it? and do i need it? the tranny that is in my car now has a one wire plug im not sure of what tarnny it is..im thinking either a 200 or 250
Old 03-20-2008, 09:38 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
IF there is an electrical connector near the shifter linkage on the drivers side of the case... it is a t-350C or a t-250C trans.
To determine the t-250C ... look near the cooler line fitting area on the case (passenger side)... IF there is a threaded stud with nut sticking out of the case. It is a t-250C trans. Weak tranny , do not use for performance.
The electrical is for the converter clutch control solenoid.
Old 03-21-2008, 01:55 PM
is the 250c pan different from the 350c pan? and if it is the 350c can i drive without that plug hooked up? and what kind of converter do i need for the tranny?
Old 03-23-2008, 07:39 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Pan is same shape , size, bolt pattern
converter clutch wires can be unhooked.
you must use a t-350C converter,,, the splines on the trans stator & input shaft are located in different positions from a non lock up converter.
T-350 and T-350C What's the difference? 83elky Transmission - Rearend 17 03-10-2008 12:23 AM
Replace TH350C with TH350? 666ross Transmission - Rearend 2 11-03-2007 10:13 PM
ok, th350 converter on a th350c fast68 Transmission - Rearend 1 03-17-2007 10:50 PM
How to convert T-350C to a T-350 65 streeter Transmission - Rearend 10 01-02-2006 09:03 AM
TH350 or TH350C HiPoVAN Transmission - Rearend 2 05-31-2003 08:32 AM
