TH350 or TH350c identification - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-22-2010, 08:13 PM
I am trying to identify a TH350 from a TH350c. I have a 1970 Nova that I changed the transmission on. The original transmission cranked from the new engine I installed. The new transmission was from a 1970 Chevelle but I'm not sure if it is original. This transmission has a small pipe on the right side in the top right. Looks like it drains extra fluid, not sure. The old transmission does not have this. the numbers on it say 6261736. Any hints would help.Thanks
JD
Old 03-22-2010, 09:02 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
JD
you are looking at the breather tube.... what you call pipe ,
t-350c has an electrical connector on the driver's side above the shift linkage.
Input shaft has a polished tip on the end of the shaft. NON t-350c has no polished tip, only splines
Old 03-23-2010, 01:16 AM
Wiki Edits: 85
http://www.crankshaftcoalition.com/w...identification
th350 or th350c? malibus~most~wanted Transmission - Rearend 5 03-23-2008 07:39 AM
T-350 and T-350C What's the difference? 83elky Transmission - Rearend 17 03-10-2008 12:23 AM
Replace TH350C with TH350? 666ross Transmission - Rearend 2 11-03-2007 10:13 PM
How to convert T-350C to a T-350 65 streeter Transmission - Rearend 10 01-02-2006 09:03 AM
TH350 identification?? finnmn Transmission - Rearend 2 11-12-2002 05:11 PM
