th350 or th700r4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-29-2007, 12:13 PM
47chevrolet's Avatar
BuRnIn RuBbEr
Last journal entry: 350
th350 or th700r4
Same just the 700 has overdrive which one takes more. ima drop a 350 in my s10 is the r4 the tranny i want
Old 03-29-2007, 01:05 PM
fast68's Avatar
likes chevy trucks & boobies
70Or4 is the 4 speed automatic and is non ECM controlled
in the late 80s GM tranies were renamed and the 700r4 were renamed to 4L60 for non ECM controlled, and 4L60E for ecm controlled
the 2004r was the smaller and shorter in length 4 speed auto overdrive tranny and was mostly in the oldsmobiles and buicks and such
700r4 were shorter in some of the later caprices and in the vettes
about 1.5" shorter
Old 03-29-2007, 04:03 PM
BuRnIn RuBbEr
th700r4
it is a good racing tranny? like ok pull up to the light and blow someone away
Old 03-29-2007, 04:53 PM
JJ350's Avatar
47cheverolet, it takes more than a trans. to like pull up to a light and blow someone away... but both trans (i believe) can be built up to take some good hp. I guess it depends on if you want overdrive or not...
Old 03-29-2007, 05:24 PM
427v8's Avatar
C6, the C5 of tomorrow
Wiki Edits: 7
It's a better all around tranny than the 350.
Takes a little more work and $$ to make it really tough though.
But you'll love the OD
Old 03-29-2007, 06:21 PM
Lonestar's Avatar
"May the Schwartz be with you"
Last journal entry: Finally getting going...
Deciding which trans is the better choice for your application is dependent upon what you have for a setup and what you desire out of your vehicle.
Both can be built to handle the load, but with the overdrive in the R4 you can run a steeper rear end ratio and still maintain acceptable RPM's cruising down the highway.
What is your current differential ratio and how much highway driving do you plan on doing?
Old 03-29-2007, 11:25 PM
BuRnIn RuBbEr
rear end
3.72 ima use with limited slip 14 inch wheels with the od about 24.5 inches
i already now the gear ratio calculator so yea i think the 700 would be bad ***
th350 in 67 Tempest csob Transmission - Rearend 1 02-19-2006 10:45 AM
TH350 wont do anything - a few questions justchris Transmission - Rearend 2 02-15-2006 12:56 PM
T-350 to 700r4 swap? trumick Transmission - Rearend 6 09-23-2005 09:19 PM
TH350 to M21 or TH350 to 700R4 thecamaroguy Transmission - Rearend 6 02-10-2005 02:18 PM
85 camaro 700r4 to th350 drewkuch Transmission - Rearend 5 11-09-2003 10:48 AM
