In a basic street automatic shift trans....the check ball near the modulator valve needs to be installed or the trans will have low main line pressure
At the Bonneville Salt Flats, first gear is known as 130 mph. |
why dont put a b&m 30262 shift kit it works well in my th350 and give it to me hard shifts under acceleration
may be you can look if you can put a ball in one of the sides of the separator shim according to the flow of the oil to block it. may be it is possible or tack weld the shim and then polish it just remember to do it carefully
Otherwise, use any of the shift kits, like B&M, TCI, Trans-Go. They dual feed when you install them, follow their instructions for check ball removal, etc. Jakeshoe also says HERE: "Some of the kits have you drill the feed holes way too big IMO and this can (WILL) cause intermediate sprag failure. Keep the feed holes no larger than about .135" (I prefer .125" on the 2nd feed) and keep the 1-2 accumulator function active on a TH350 it will not break parts." |
Thanks. |
you will like the way jakeshoe does his. I finished mine up this fall with the internal dual feeding and only enlarged the separator holes to .125". shifts are firm and positive not harsh like the B&M kit. My last 2 trans that had B&M kits installed didn't last. It could be unrelated though.
| th350 check fluid | Vincentnova | Transmission - Rearend | 1 | 09-23-2010 03:34 PM |
| T-400 check balls | jlwagner17 | Transmission - Rearend | 14 | 06-14-2010 10:54 PM |
| 700r4 check balls | sbc400_700r4_3.42 | Transmission - Rearend | 6 | 12-11-2008 01:48 PM |
| th350 air check? | Cape Cod Bob | Transmission - Rearend | 19 | 12-30-2007 05:47 PM |
| Turbo 475 check balls | Greg T | Transmission - Rearend | 8 | 07-11-2007 09:40 PM |
