TH350 tranny questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-19-2007, 05:59 PM
colincamaro's Avatar
Wish I grew up in the 60's
Thanks to all that have replied on my prior issues - the 67 Camaro now starts and runs all day long, but....
While the engine is idling at initial start-up, the car wants to move backwards. I can certainly hold it with the brakes, but as I let off it begins to roll in reverse. I have had to put in modified linkage as it was originally a Powerglide. (I purchased a kit specifically for the application.)
My thinking is that I don't quite have the linkage set at the right point so it is solidly in Park, but am willing to take any thoughts anyone may have.
I have also added 5-6 quarts of fluid, as I drained the trans before I installed it, but left the torque converter in and didn't mess with it. The dipstick shows an overfill situation, but I assume that when I get the shifting sorted out and into drive a few times it will be at about the right level.
Old 02-19-2007, 06:18 PM
poncho62's Avatar
Wiki Edits: 5
Make sure it is not overfilled............you will blow seals.
Does it hold in park with the engine turned off?
Old 02-19-2007, 06:25 PM
DeathRattle's Avatar
Some Punk Kid
There is a paul that holds the car in place in park, so it shouldn't roll(except for maybe a half inch). Get somebody to put an ear to the pan or use a stethoscope and listen to see if you can hear each gear. There is a tensioned roller on a rooster comb and you will hear a positive click or clunk like sound for each gear.
late shifting TH350 red_rider52 Transmission - Rearend 18 12-19-2005 09:32 PM
87 ramcharger 727 tranny questions 74huggerorange Transmission - Rearend 0 04-14-2004 08:52 AM
Pulling motor/ tranny 66 C10 66thom Engine 6 10-27-2003 09:46 AM
phew, done , tranny shift questions chevcamz28newbie Transmission - Rearend 2 08-06-2003 01:07 AM
Tranny fluid heating up engine??? black66 Engine 1 07-13-2003 09:18 PM
