th350 trans - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-20-2006, 02:53 PM
th350 trans
i got in my truck and started going down the road and it woud not shift. so i floored it. when it got up about 30-35 i let off and it shifted kinda hard. but it wont shift anymore gears. anyone got any ideas????? also when driving i get the rpms up and let off and then gas it again the trans seems to wait for the rpms to get back to where they were before it picks up speed again???
Old 09-20-2006, 05:34 PM
BOBCRMAN@aol.com's Avatar
Is the throttle position cable (kickdown) adjusted correctly? Is the vac modulator good?hooked up?? Fluid level??
Old 09-20-2006, 06:54 PM
follow the vacuum line from the engine down to the transmission and see if it came off or is cracked or leaking.if this happened all of a sudden its a good chance that line to the modulator is off or damaged.that transmission will act really strange without it working right
Old 09-20-2006, 07:45 PM
th350
fluid is good. i will try the vacum line tomorrow. as far as the kickdown im not sure? i tried to figure it out by the book i bought. i took it off and it had some play in it then you can pull it a little faether. thanks guys for the help!!
Which TH350 trans? Streetmaster Transmission - Rearend 2 01-02-2006 01:46 AM
th350 or 700r4 trans hambone0_5 Hotrodding Basics 5 12-29-2005 11:09 AM
Automatic trans does NOT shift automatically?! TH350 killerformula Transmission - Rearend 6 10-19-2004 09:31 AM
TH350 Trans Slipping when warm 64SS Transmission - Rearend 1 09-29-2003 08:32 AM
powerglide trans or th350 in 54 chevy? DeathByGreaser Transmission - Rearend 10 01-01-2003 09:52 AM
