th350 trans id - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-09-2007, 02:34 PM
excaliberprime's Avatar
Last journal entry: back for 2014
th350 trans id
am i correct in thinking some th350's where built a little different then others.
how would i find out what my trans came out of ? the only numbers on the trans are191198463 located on the right hand side on the lower lip of the bell housing. the other number is 110214-a-8340820 i belive and it is located on the driver side about mid bell housing. im posting a few pics. these are the only numbers on this trans. is the trans a after market trans. i was told it could be a boss because of the location of the 191 number but iv also found that it coul just be a pre 72. any one have any more information about this
Old 03-09-2007, 02:52 PM
i believe....
the 350 and the 400 are damn near identical... bolts up the same...
The Stray
Old 03-09-2007, 03:37 PM
re: th350 trans id
Yes there was a heavy duty model call a "TH-375", same option was available for the TH-400.
Other than trying to look up the serial number I'm not sure how you would know. Otherwise the case is identical.
Old 03-09-2007, 03:46 PM
i was...
actually gonna use the t350 to bolt up to the turbo 400 motor in the 78 trans am i have... but... yea... whats it going into and what motor are you putting it against???
The Stray
Old 03-09-2007, 05:30 PM
Will I ever get it done?
Last journal entry: Hood
The Stray
Well, they bolt up to the block the same assuming you have the TH350 Chevy bolt pattern bell housing compared to a TH400 Chevy bolt pattern bell housing. Same thing goes for the BOP bell housing bolt patterns. Then there are the dual pattern units.
After that, the TH400 has a case mounted center support inside. This makes the body of the tranny longer. It also usually uses a larger output shaft. So, the rear mount location is different, meaning you move the crossmember back for a 400. You will most probably have to get a 400 yoke for a 400 or a 350 yoke (fits glides and most sticks as well) for a 350. The OAL is most probably different (not sure if the 9" tail on the 350 makes it the same as a 400 length or not), so you will have to get the driveshaft cut (or a new one if you are going to a shorter trans).
Here is a great page.
http://www.tciauto.com/Products/TechInfo/trans_dims.asp
Just checked there and it looks like the 12" tailhousing 350 and the "D" tailhousing 400 are the same length.
Old 03-09-2007, 05:36 PM
here are the picks of my trans im surtain its a th350 just not shure as to anything more than that. it does not have the torque lock up
ID:	19328   Click image for larger version
ID:	19329   Click image for larger version
ID:	19330   Click image for larger version
Old 03-09-2007, 05:37 PM
its going into a chevrolet c10 76 with a 350
Old 03-10-2007, 08:28 AM
81BlackTA's Avatar
That is definitely a th350.
Old 03-10-2007, 09:26 AM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Pan shape will tell you that it is NOT a 400, which is a totally different transmission.
Variations in 350s can be ID'd by the electrical connections on the trans for a lock-up torque converter, etc.
Old 03-17-2007, 08:51 PM
fast68's Avatar
likes chevy trucks & boobies
yes the shorter th400 are virtually identical length a the 9" th350
yep
and thats a th350 as long as its a 9" tail, or if theres not a big X across the pan
if there was then its a TH250
good luck
T-350 trans to electric speedometer? Hero2112 Electrical 13 02-25-2011 12:32 AM
Which TH350 trans? Streetmaster Transmission - Rearend 2 01-02-2006 12:46 AM
th350 or 700r4 trans hambone0_5 Hotrodding Basics 5 12-29-2005 10:09 AM
TH350 Trans Slipping when warm 64SS Transmission - Rearend 1 09-29-2003 07:32 AM
powerglide trans or th350 in 54 chevy? DeathByGreaser Transmission - Rearend 10 01-01-2003 08:52 AM
