We're winning the case!
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 12-21-2003, 03:52 PM
levens levens is offline
th350 trans question
i have a 78 chevy k10 with a th350,how much fluid does the th350 hold or need?
thanks
Old 12-21-2003, 04:16 PM
Tissue Tissue is offline
The TH350 takes 4-5 quarts depending on your transmission pan size.(there are deep pans that you can buy but stock pans hold 4)
Old 12-21-2003, 04:25 PM
adtkart adtkart is offline
adtkart@aol.com
Actually a TH350 takes about 10 qts to completely fill it if dry(including convertor). If changing fluid and filter it will usually take 4-5.
Old 12-21-2003, 05:16 PM
ok i just swaped tranmissions so should i put a full 10 qaurts or just 5?the converter had some when installed!
thanks
Old 12-21-2003, 05:45 PM
camaroman7d's Avatar
camaroman7d camaroman7d is offline
The best way to do this is, if the converter is dry (new). pour a quart or so in the converter. Pour another 4-5 in the tranny. Start the vehicle go through the gears, check the fluid level. Add a quart and check, continue until you are on the stick at this point add smaller amounts until you reach the level you want. I prefer to do all this with the car running (in park). Whatever you do don't just go out and pour 10-12 quarts into the tranny. There is no way to know how much it will hold for sure, if you have a deep pan, large or small converter, if the tranny is truly dry, etc... all will have an effect on the amount needed. You don't want to overfill the transmission either, this can actually cause damage.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
