TH350 transmission leak from dip stick - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-09-2012, 09:09 AM
I recently bought a 59 Chevy stepside and the guy had just dropped a reco motor and transmission in it. It has been leaking and I finally found from where. The outside of the dipstick where it enters the case. I have 2 O rings on the inside and I have smeared gasket goo on the outside. I have closed it up and it leaks. Any recommendation on a seal that I could put on with tran fluid still in?
I would hate pull it all down for the 6th time.
Old 01-09-2012, 08:15 PM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
Are you 100% sure that you are using the correct o-ring ? Have you checked the tube over closely for any cracks or grooves. If the dipstick tube is in good shape and you are using the correct o-rings, then I would check the bore that the o-rings go in for damage. You shouldn't have to use any kind of sealer on it.
Old 01-10-2012, 10:21 AM
bentwings's Avatar
bentwings
Lokar makes dipstick with a positive lock and a good seal with a nut and washer on the inside. Takes care of this leak. The only place it doesn't leak on mine. haha
The converters bleed down on these when they sit. I think there is a check valve in the vlve body but it apparently doesn't work very well. All of my rebuilt ones leaked somewhere.
Old 01-10-2012, 04:38 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Are you %100 sure that it's going all the way down and is in straight ?
Cole
Do you drive a stick? (aka manual transmission)? crazygutgut Hotrodders' Lounge 73 11-09-2005 12:17 AM
Bad TH350 Leak jvenice Transmission - Rearend 3 11-03-2003 07:19 PM
TH350 Leak just_football Transmission - Rearend 4 09-20-2003 01:15 PM
Transmission stick blowsout phoneypony Transmission - Rearend 5 06-11-2003 06:40 PM
oil stick leak iroc1989 Engine 2 11-28-2001 04:41 AM
