TH350 Tricks/Mods - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-14-2008, 11:13 AM
6426yy's Avatar
TH350 Tricks/Mods
I'm wondering what "extras" everyone does to their trans.
My last rebuild was a success and I wan't to get a little more serious for my camaro project.
I plan on installing:
Fresh master rebuild
hardened outer race
machining direct apply piston for extra clutch
using four bushings in sun gear
and a few other little things
I'll probably use the transgo1+2 kit possible stage 3 full manual what are pros/cons
Will this kit (2) downshift to 1st at any speed automatically?
On muscle car they showed using something out of a 700r4 don't remember what that was and sandblasting the steels. Does anyone else do this?
I don't think I'll need the 36 element sprag and drum as I've read.
Car currently has 3.42's and I plan on switching to 4.10's
Engine will be a 383 with WP S/R torquers 2.02/1.60 around 10:1
still looking at cams. I'm going to run a tunnel ram with dual 390 Holley's.
Sorry for the long post, I've done a bunch of searching but haven't found any
different tricks. Thanks
Old 01-14-2008, 08:43 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
hardened outer race
IF you do not drill a hole in the sun gear bushings (dual set at each end) , you can cut off the oil flow to the planetary .
The 700 uses a wider low roller clutch in the center support. This will require you to check the clutch pack clearance of the low/ reverse clutch.
The 700 center support has a few different heights.
I do not recommend the steels be bead blasted. Scuff them up with red scotch bright or similar process.
The -2 kit TransGo will down shift at all speeds. The kit has a spring that blocks the low gear over-ride valve in place
TH350 parts and pieces... CamSweet Transmission - Rearend 5 12-05-2007 03:38 PM
Stock TH350 capacity 307malibu Transmission - Rearend 7 11-01-2007 10:16 AM
TH350 vs. 7004R? Also, gears? 307malibu Transmission - Rearend 2 10-18-2007 08:05 PM
T-350 to 700r4 swap? trumick Transmission - Rearend 6 09-23-2005 08:19 PM
TH350 to M21 or TH350 to 700R4 thecamaroguy Transmission - Rearend 6 02-10-2005 01:18 PM
