TH350 Troubles - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-22-2007, 03:28 PM
newbielike's Avatar
TH350 Troubles
Ok I finally got the torque converter set right, 1 /18" from the TC mounting brackets to the face of the bellhousing. Everything's hooked up, vacuum lines etc, the fluid's full. I started off adding 4 quarts and I started the truck and let it run for a minute then added 5 more quarts and let the engine run for a few minutes. Then I went through all the gears several times, note I was still parked I never took off in it, I checked the fluid and it was about a half a quart low so I added some and went through the gears again and checked the fluid.
This is a fresh rebuilt TH350- so I took off down the road and it shifted from 1st to 2nd fine but wouldn't shift into 3rd. So I come to a stop and dropped into low 1 and shifted into 2nd fine but still no 3rd. If I take off in drive it goes through 1st and 2nd and then just winds up and if I suddenly let off the gas it drops out of gear like it's in neutral and I have to stop and it will catch again. Not sure what would cause this, any ideas?
The original problem with this tranny was that the clip on the linkage thats inside the oil pan had broke off and it dropped into 1st and wouldnt come out of it. It was in 1st gear no matter what position the linkage was in but I figure while they had it apart I'd go ahead and have it rebuilt ya know.
Old 12-22-2007, 03:40 PM
runn141's Avatar
1st thing i would check is the vacuum modulater, make sure it is hooked up.
Old 12-22-2007, 03:51 PM
newbielike's Avatar
yep it is, i've been there before but when it's not hooked up it wont shift out of 1st, i can get 1st to 2nd just no 3rd.
Old 12-24-2007, 04:54 PM
DHMag's Avatar
kickdown cable set correctly ? have you checked the fluid pressures ?
TH350 parts and pieces... CamSweet Transmission - Rearend 5 12-05-2007 03:38 PM
Stock TH350 capacity 307malibu Transmission - Rearend 7 11-01-2007 10:16 AM
TH350 vs. 7004R? Also, gears? 307malibu Transmission - Rearend 2 10-18-2007 08:05 PM
TH350 wont do anything - a few questions justchris Transmission - Rearend 2 02-15-2006 11:56 AM
th350 troubles SlammedC10 Transmission - Rearend 6 12-13-2002 03:21 PM
