th350 troubles - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-18-2010, 01:10 PM
markzepp820's Avatar
th350 troubles
Hello, I have a non-lockup th350 trans and i have this leak that just won't go away & would greatly appreciate some advice. My leak is coming from the 1-2 accumulator cover. So i replaced the o-ring. The old one was bad... dried up, brittle and hard. Anywase after i replaced it, the leak stopped at the accumulator but started leaking out of the pressure test ports by the accum. I put teflon tape on the threaded plugs and still leaks. So i'm wondering if the pressure is to0 high in my trans... maybe bad pressure regulator? I just can't figure it out I even put quick-steel epoxy on the pressure port to the left of the accum. and it actually stopped leaking. I tried the same for the port to the right of the accum. but it still wants to leak. Any suggestions? thanks, Mark
Old 02-18-2010, 10:33 PM
SSedan64's Avatar
Make sure someone hasn't over tightened the port plugs and cracked the case.
Old 02-28-2010, 09:32 PM
th350 troubles
okay thanks
TH350 Troubles robins44 Transmission - Rearend 12 05-11-2009 09:54 AM
Th350 troubles BadBowtie_84 Transmission - Rearend 2 11-04-2008 12:58 PM
T-350 Rebuild Tech jakeshoe Transmission - Rearend 10 10-05-2008 03:58 PM
TH350 Troubles newbielike Transmission - Rearend 3 12-24-2007 04:54 PM
th350 troubles SlammedC10 Transmission - Rearend 6 12-13-2002 03:21 PM
