th350 vacuum modulator - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-19-2006, 11:01 PM
this is something that i should know but don't. which way do i turn the screw in the vacuum mod to make the shift points later?
thanks
-Matt
Old 04-19-2006, 11:13 PM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
i thought that was for the stoutness of the shift, i am sure if you give B&M a shout they will have the right answer, when you find out ,post the answer I would like the answer to this one also
Old 04-20-2006, 09:15 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
thanks
-Matt
turn the screw clock wise to tighten the preload on the internal spring of the modualtor.
this will provide slightly later / firmer shifts at light to moderate throttle .
Old 04-21-2006, 09:19 AM
thanks guys, i appriciate the help
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 01:38 AM
PCV & Modulator - can they share vacuum? Mauboo Engine 6 03-16-2005 12:43 AM
Do I need the vacuum modulator? 65 streeter Transmission - Rearend 4 07-04-2004 03:03 PM
at wits end on ford brakes....... crazy larry Suspension - Brakes - Steering 30 04-06-2004 06:39 AM
ok to use same vacuum line for vacuum advance and tranny vacuum modulator? brian400ex Engine 4 02-19-2003 03:25 PM
