-   -   TH350 Valve Body (http://www.hotrodders.com/forum/th350-valve-body-158805.html)
1985CHEVYCARLO 05-20-2009 03:05 PM
TH350 Valve Body
Does any one know what size the valve body bolts are for a th350??
cobalt327 05-20-2009 03:25 PM
I want to say mainly 7/16" (been years since the last one I did)- a couple are different, but I think if you had 3/8", 7/16" and 1/2", you should be able to pull the v-body.
There are quite a few- use at least a ratchet w/short extension or a speed wrench for the majority of them.
tnsmith10 05-20-2009 06:34 PM
5/16 x 18 size bolts, as for length, around 1 1/2".
mmerlinn 05-21-2009 01:49 AM
All 350 valve body bolts are the same size (5/16 NC) with slightly different lengths. All had 1/2" heads.
