Th350 Valve Body Problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-13-2008, 08:28 PM
Well just recently rebuilt my TH350 and everything was working great until I installed my TCI manual valve body. I have reverse but no forward gears and my line pressure is super low. I guess the question I have is do I have to install anything from my OEM valve body into my TCI valve body because the terrible directions don't tell me. The part number is 321100. Thanks guys!
Old 11-14-2008, 03:59 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
In my opinion the instruction sheet is quite clear.
With the low pressure you report;
Did you plug the necessary holes as instructed?
Did you leave the vacuum modulator valve in place?
Have you called TCI?
Correct way to set valves on sbc w/ solid flat tappit camshaft? Joshua Lee Engine 17 02-09-2011 05:55 PM
700R4 Why are the TCI manual valve body instructions so lousy? Bayley Transmission - Rearend 24 02-16-2009 12:49 PM
transbrake valve body problems?? eight90 Transmission - Rearend 3 09-10-2007 02:01 PM
valve bodies for th350? gilliganspl Transmission - Rearend 4 05-03-2004 03:26 PM
Manual Valve body Big86inthestixx Transmission - Rearend 2 12-12-2003 02:08 PM
