Measuring tire diameter is not exactly correct.
Measure from the ground up to the center of the rim and double it. |
rpm
That's right slippage and the math is spot on , on a NEW tire no miles as it wears the size changes, and a tire grows as you speed goes up just a lil , the front tires are not in play because they are not the drive axle, my figures on my set up is 420ish cubic blown small block chevy with th350 with 3.85 gears and 275/60/15 rear tire at widest tire I can run and at 65mph math says 2985rpm and my tach. Reads about 3100ish so about right , 275 is the width in mm and ratio 60 is the sidewall is 60% of the width of the tire, you can change tires(rear) and change your gearing crazy huh just take top number in the equation that I sent you and divide it by different tire sizes like (26inch 28inch 30inch tire and see how much you rpm changes)
That would only give the tire highth.One would have to mark the tire and measure the total distance of one revolution on the ground to be exact and even that measurement would change with tire speed to a degree. In his case, I don't think the tires are as much a problem as the stall speed is higher than the speed rpm he wants to cruise at. So, either change the rear ratio or reduce the stall speed of the converter to reduce slippage at cruise speed. Only problem is if he changes rear end ratio mileage will suffer. Change the stall speed and it will improve. Slippage also builds heat (bad).
Not a big deal, but measuring from the ground up is correct.
My wife had a flat tire before and she told me ''its not too bad, its only flat on the bottom.'' |
| TH350 transmission oil level at kickdown cable seal | Elder Rodder | Transmission - Rearend | 3 | 11-13-2010 07:22 PM |
| TH350 low tech,a simpletons guide | sooper | Transmission - Rearend | 1 | 11-30-2009 10:56 PM |
| th350 int clutch height to low? | sooper | Transmission - Rearend | 5 | 11-27-2009 03:33 PM |
| Test for low drag calipers | powerrodsmike | Suspension - Brakes - Steering | 2 | 05-16-2009 01:37 PM |
| Geared too low? please help??? | magic781 | Transmission - Rearend | 14 | 07-30-2004 07:48 PM |
