th350 weight - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-19-2007, 08:30 PM
th350 weight
how heavy is the th350? I am planing on some work. I need to drop the trans, unless you know a better way to get the converter out?
Old 10-19-2007, 08:46 PM
GaryD's Avatar
Don't know the weight, but here's a tip on getting it down. I have one of the cheap $50 motorcycle jacks from Pep Boys that doubles as a dandy tranny jack. It has a wide enough platform that it supports a lot better than the old floor jack with a piece of plywood did.
Old 10-20-2007, 08:28 AM
XNTRCI-T's Avatar
AKA Lee in KC
Having recently lifted my TH350 I would guess it was around 90#. That was with no fluid and no converter.
Old 10-20-2007, 08:31 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
trans has to come out to remove the converter... the input shaft seems to hold the converter in place.
You need a jack of some type to avoid injury. Be careful!
The D.O.T. gonna gitcha. coldknock Hotrodders' Lounge 32 10-31-2007 06:33 AM
External/Internal balancing ap72 Engine 22 04-29-2006 10:25 PM
tryin to figure out the weight of truck 5.7s10 Hotrodding Basics 6 01-14-2006 08:40 AM
Best Rust Inhibitor? bigbrowndog Body - Exterior 45 11-21-2004 08:26 PM
car still WHEEL HOPS why???? tyson Transmission - Rearend 19 08-11-2003 11:28 AM
