th350 weird shifts - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-13-2011, 03:42 PM
th350 weird shifts
hello everybody i have a sbc cuttlas supreme 1981 with a th 350 transmission and b&m shift kit on street/strip mode a few days ago the transmission does not change and it starts running in third and when i shift down to 2nd. it does not change and if i change to first the tires brakes and then the car does not run until i push the gas pedal at 3000 rpm +- it shifts into first and start running a dude tells me that may be the governor is stuck what could be the reason for this fail? do ineed to pull apart the transmission? or just check the governor
thanks in advance for your info
th350 lazy shifts sbcvtc Transmission - Rearend 4 01-22-2011 08:02 AM
TH350 noise when shifts....fed up GUNTHER19820 Transmission - Rearend 4 03-08-2010 07:42 PM
700r4 now shifts and sounds weird roomchirp Transmission - Rearend 7 05-10-2009 05:42 AM
1977 th350 shifts from 1-2 late 77chevy254 Transmission - Rearend 1 12-13-2008 12:47 AM
TH350 tranny shifts to quick? "SLOWMOE" Transmission - Rearend 5 06-04-2004 01:28 AM
