th350 will not kick down - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-13-2005, 08:08 AM
Howdy folks,
I have a th350 dehind a built 355 in an 83 k10 silverado. Tranny will not kick down. Installed new detent cable when I rebuilt engine recently and have it adjusted properly @ wide open throttle. Also put a 2600 to 2800 stall converter in and it does not appear to be stalling. Hold your foot on the brake and it wants to go @1100 rpm. Probably got took on the converter(although new). Any info would be greatly appreciated.
Thanks, Sam
Old 02-13-2005, 12:04 PM
stu stu is offline
Readjust the cable.
Does the bracket allow full travel of the gas pedal?
If not you will have to bend it to allow for this then adjust the KD cable.
Old 02-13-2005, 12:39 PM
Unless I'm missing some info, i've got the cable adjusted so that when you are at full throttle the detent cable has been extended to its max point.
Old 02-13-2005, 12:40 PM
poncho62's Avatar
Wiki Edits: 5
Maybe the other end has come disconnected.
